Regarding Laminar/Inviscid Flows
Old   September 10, 2015, 06:11
Default Regarding Laminar/Inviscid Flows
hwsv07 is on a distinguished road
If I want to simulate a very low turbulence problem, how should I know if I should select laminar or inviscid model in the fluid solver?
Thanks!
hwsv07 is offline   Reply With Quote
Old   September 10, 2015, 06:25
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Thanks!
Your question seems strange ... if you want to set a laminar model that's only for simulating turbulence in a DNS formulation. On the other hand, if you set inviscid flow you should be aware that you cannot simulate confined turbulence and you cannot perform a DNS.
So, explain in details what you want to simulate
FMDenaro is offline   Reply With Quote
Old   September 10, 2015, 07:10
maybe i am not framing the question well.
I want to compare RANS results with an analytical model (which does not include any turbulence dissipation).
so if i want to have CFD results that can be compared with my analytical model (which does not account for turbulence), how should I set my CFD model? invisicd or laminar?
thanks!
Old   September 10, 2015, 07:25
Still not clear ...RANS provides a statistically averaged solution, what about the type of your analytical solution? I see you need for sure a viscous model
Old   September 10, 2015, 08:17
yes my purpose is to show the difference between a RANS solution and a inviscid analytical model.
but i also want to check that when I select a invicid/laminar model in the fluid solver, the solution should equal or almost the same as the invisicid analytical model.
making sense here?
so my question is: whether i should choose a inviscid or laminar model in the fluid solver to compare to my inviscid analytical model.
Old   September 10, 2015, 08:30
honestly, I don't see the sense in making comparison between RANS and an inviscid model.... But without more details I can't say much more...
I suppose you should compare an Euler simulation and your inviscid analytical solution
Old   September 10, 2015, 08:47
sorry if i was not clear.
forget about the RANS part.
I am trying to comparing between inviscid model to that from a fluid solver. so the question is what flow physics should I specify for the fluid solver: invisicid or laminar?
Old   September 10, 2015, 08:58
The Euler inviscid model
Old   September 12, 2015, 00:46
Antanas is on a distinguished road
In my understanding when you choose laminar flow that means that solver solve non-averaged N-S equations. Indeed this equations can resolve turbulent structures of different length scales depending on mesh resolution, that is called Direct Numerical Simulation and it's very costly for most practical (turbulent) flows. So it better be used for really laminar flows, i.e. flows where viscous forces are large compared with inertial forces, so characteristic Re number is low. Inviscid flows in contrast are those where viscous forces are neglible and Re is large. In this case we obtain Euler equations from N-S equations. If your CFD code doesn't have ablitiy to solve such equations you can try to set low viscosity in material props and use free sleep conditions on walls. And this won't be laminar flow.
Correct me if I'm wrong.
Antanas is offline   Reply With Quote
Old   September 12, 2015, 16:42
i think both of your replies make sense to me.
for my case, since I am trying to validate results between a inviscid analytical model to that from a fluid code-solver, i should be using prescribing a fluid with very low viscosity or in this case, the inviscid NS equations.
thanks.
Derivation of the pressure-correction equation for compressible flows luftraudi Main CFD Forum 0 July 17, 2012 06:35
SIMPLE pressure correction in compressible flows Maarten de Jong Main CFD Forum 7 April 30, 2012 02:23
y+ in high Pr flows vishyaroon Main CFD Forum 0 April 15, 2010 14:24
Laminar Solid-Liquid (Two-phase flows) flows in CFX freemankofi ANSYS 0 April 8, 2010 16:59
Free surface flows and multiphase flows Vidar Main CFD Forum 0 September 18, 2008 05:05
