Spacing od DES
Old   November 19, 2008, 02:30
Default Spacing od DES
Daniel WEI
Dear all,
i am learning DES (Detached Eddy Simulation). In order to save the grids, it's better to use DES with large spacing in streamwise and spanwise, (Please correct me if I was wrong), to control this effect, do you always use structured grids near the surface.
Well, I am using structured grids near the surface and unstructured mesh away from the surface of the obstacle, but I am not sure whether it is a good idea...
Any hints? Thanks in advance.
Regards, \Daniel
Old   November 23, 2008, 17:10
Default Re: Spacing od DES
ju
http://ntrs.nasa.gov/search.jsp?R=666995&id=4&qs=Ntt%3Ddetached%252Beddy%252Bsimulation%252Bgrid%26Ntk %3Dall%26Ntx%3Dmode%2520matchall%26N%3D0%26Ns%3DHa rvestDate%257c1
Or http://hdl.handle.net/2060/20010080473
Spanwise Length and Grid Refinement for SAS-SST, DES, and LES Josh CFX 5 October 14, 2010 19:47
How to use DES well? Daniel Main CFD Forum 0 October 26, 2008 05:59
DES ( SA+LES) vs DES ( kwSST+LES) for bluff body Phil Main CFD Forum 0 January 8, 2008 09:04
Problem with DES model mehul Phoenics 0 April 12, 2006 08:00
Problem with DES model mehul Fidelity CFD 0 April 12, 2006 08:00
