January 27, 2009, 13:24 |
laminar flow in a channel/pipe
Dear friends, i am trying to simulate 2D laminar flow in a channel (including entrance length)using FV Method on colocated grid. for this following boundary conditions i have used
Inlet BC: , u-component = given, v-component =0, Outlet BC: Pressure = given,i.e.pressure'=0.0, d(u,v)/dx=0 ie. u(i,j)=u(i-1,j) and so for v at Walls u,v=0, dp'/dy=0 in case of pressure correction for cell just next to left boundary p'doesn't come into picture at left boundary as in continuity equation we can directly substitute u left value. then how to find this p'at left boundary as we need p at left boundary for calculating u at cell just next to left boundary. (this unknown p at left boundary becomes face value of p for cell just next to left boundary). i just tried by taking p'(1,j)=p'(2,j)...i got parabolic profile but with maximum value 3 time higher than uavg. ie.u at left boundary. at the same time i got some noises in the result at the right boundary. i think the right way is apply following equation to get p(1,j) from P(2,j) -dp/dx=-del.(mu*del_u)+rho*du/dt+del.(rho*V*u) then how to apply this at the fictious cell of zero volume at the left boundary. any suggestions |
Boundary Layer of Laminar Flow over a Flat Plate | Blasius_Pohlhausen_Crocco | Main CFD Forum | 12 | September 30, 2013 17:35 |
Convergence of laminar flow model for high Re | Chander | Main CFD Forum | 0 | December 16, 2010 05:10 |
How to enforce laminar flow while using k-e | Grzegorz Kondora | FLUENT | 0 | January 28, 2009 10:35 |
grid for laminar flow | kim | FLUENT | 2 | April 4, 2002 02:44 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
