How to calculate the computational resource requirement?
Old   March 10, 2012, 09:21
Default How to calculate the computational resource requirement?
k_k
Kailash
k_k is on a distinguished road
I have a model with 10 million cells, if the solution takes 3000 iterations to converge, how do I estimate the computational resource requirement (number of cores, memory RAM) so that I get the solution in n hours (say 12)?
Thanks
Kind Regards
k_k is offline   Reply With Quote
Old   March 10, 2012, 16:18
Arjun
arjun will become famous soon enougharjun will become famous soon enough
Thanks
Kind Regards
A typical segreggated solver usually takes about 0.6 - 0.8 GB per million cells. So max you would need is 10GB to run this case.
Which solver are you going to use.
arjun is offline   Reply With Quote
Old   March 11, 2012, 04:20
k_k
Kailash
Thanks Arjun, I plan to use Numeca or Fluent.
Old   March 11, 2012, 07:57
Arjun
Till with fluent 6.3 what i wrote was valid. I have not used recent versions of Fluent but it will not be much off.
Good luck.
[OpenFOAM] Saving ParaFoam views and case sail ParaView 9 November 25, 2011 15:46
calculate values for eps and k from Re or u????? sbar OpenFOAM Pre-Processing 5 August 16, 2010 04:10
Problem with paraFoam ata OpenFOAM 14 November 30, 2009 04:23
[OpenFOAM] Xwindows crash with paraview save srinath ParaView 1 October 15, 2008 09:37
Short Course: Computational Thermal Analysis Dean S. Schrage Main CFD Forum 11 September 27, 2000 17:46
