February 14, 2009, 09:43 |
LES Model
I am using Dynamics Large Eddy model on a simple structured Cartesian grid. I use staggered grid with pressure inside the cell and velocities on the faces. Related to LES, is there any difference to allocate the vraiables (Cs, turbulent viscosity, etc. ) in the "centre of cells" or "vortices"? Thanks
February 21, 2009, 14:27 |
Re: LES Model
Yes.
February 22, 2009, 17:35 |
Re: LES Model
JK, Thanks for reply. But I would like to know, what is difference, if we set the turbulence variable on the center of cells, or on the grid point? And where I must put the these variables? In the center or on the grid points?
February 23, 2009, 23:50 |
Re: LES Model
I've written LES code with velocities on faces, pressure at cell center and turbulence variables at cell vertices. It worked for me.
buoyantBoussinesqPisoFoam can't use LES model ? | panda60 | OpenFOAM | 1 | December 30, 2009 17:41 |
Implementing a new LES Model in OpenFoam | fs82 | OpenFOAM | 6 | October 13, 2009 09:58 |
help urgent LES model for a swimming pool | marion | FLUENT | 0 | June 4, 2007 05:26 |
Anisotropic subgrid model (LES) | h.jordi | Main CFD Forum | 1 | August 29, 2002 15:49 |
LES pipe model | Matt | FLUENT | 1 | August 21, 2002 14:19 |
