udf file editing
Old   February 6, 2009, 03:02
Default udf file editing
srihari
hi
im doin a rotary vane pump problem and i have a the udf file tht fluent has given..wht are the changes that i have to make in tht udf file for my new problem..that is if im going for another typical problem what are the changes that i have to make as im facing problem to read the UDF and i dont know to make a new UDF file.if anyone could help me in this it would be useful.thanks hari
Old   February 27, 2009, 09:34
Default Re: udf file editing
varadaraj
hai, i am in need of the udf file .....
Old   February 28, 2009, 00:16
srihari
get me ur mail id so that i can send u..
Old   February 28, 2009, 01:34
varadaraj
hai this is my id ......
Old   February 28, 2009, 01:43
varadaraj
venkat.m@tcs.com
Old   February 28, 2009, 01:50
varadaraj
hai my id is venkatn.m@tcs.com...
Old   February 28, 2009, 02:37
varadaraj
hai thanks a lot.. i am doing on variable displacement vane pump ... i can use this files? ...
Old   February 28, 2009, 02:41
srihari
see do u have the pdf for this file..this udf files are for rotary vanepump problem whch will work for both 2d and 3d...actually there are some geomtery constraints tht they have given whch we have to follow and change the input.txt file according to ur problem.then this udf will work..please try it and let me knw the eror mesage u get(if u get so)..will help u later..try using this for variable as well..lets c whetr it works.. regards hari
Old   February 28, 2009, 02:45
raj
k i will try it ....
[OpenFOAM.com] OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10 electrosin OpenFOAM Installation 40 May 31, 2016 05:11
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 17:33
PHI file structure Eugene Phoenics 9 November 2, 2001 22:00
