LBM for Poiseuille flow in stationary flat plates |
February 6, 2016, 06:43 |
Hamed Abdul Majeed
Rep Power: 13 |
Hi guys,
I am working on lattice boltzmann method LBM and currently following the book LBM by A. A. Mohamad. I have issues in the FORTRAN code for poiseuille flow for flat plates. The code file is as follows: !computer code for flow in a channel parameter (n=1000,m=40) real f(0:8,0:n,0:m) real feq(0:8,0:n,0:m), rho(0:n,0:m) real w(0:8), cx(0:8), cy(0:8) real u(0:n,0:m),v(0:n,0:m) integer i open(2,file='result') ! uo=0.2 rhoo=1000.00 dx=1.0 dy=dx dt=1.0 alpha=0.02 !nu lattice Re=uo*m/alpha !Re=400 omega=1./((alpha*3.*dt/(dx*dx))+0.5) mstep=20 w(0)=4./9. do i=1,4 w(i)=1./9. end do do i=5,8 w(i)=1./36. end do cx(0)=0 cy(0)=0 cx(1)=1 cy(1)=0 cx(2)=0 cy(2)=1 cx(3)=-1 cy(3)=0 cx(4)=0 cy(4)=-1 cx(5)=1 cy(5)=1 cx(6)=-1 cy(6)=1 cx(7)=-1 cy(7)=-1 cx(8)=1 cy(8)=-1 do j=0,m do i=0,n rho(i,j)=rhoo !Inital value density is set to rhoo=1000.00 u(i,j)=0.0 !Initial value fo u and v velcities is set to 0 v(i,j)=0.0 do k=0,8 f(k,i,j)=0.0 end do end do end do do j=1,m-1 u(0,j)=uo !Velocity at inlet is set to uo at the left most inlet (U lattice) v(0,j)=0.0 end do !Main Loop do kk=1,mstep call collesion(u,v,f,feq,rho,omega,w,cx,cy,n,m) call streaming(f,n,m) call sfbound(f,n,m,uo) call rhouv(f,rho,u,v,cx,cy,n,m) end do !End of Main Loop do j=0,m print *,kk,j,u(300,j) end do stop end !End of Main Program subroutine collesion(u,v,f,feq,rho,omega,w,cx,cy,n,m) real f(0:8,0:n,0:m) real feq(0:8,0:n,0:m),rho(0:n,0:m) real w(0:8),cx(0:8),cy(0:8) real u(0:n,0:m),v(0:n,0:m) do i=0,n do j=0,m t1=u(i,j)*u(i,j)+v(i,j)*v(i,j) do k=0,8 t2=u(i,j)*cx(k)+v(i,j)*cy(k) feq(k,i,j)=rho(i,j)*w(k)*(1.0+3.0*t2+4.5*t2*t2-1.5*t1) f(k,i,j)=omega*feq(k,i,j)+(1.-omega)*f(k,i,j) end do end do end do return end subroutine streaming(f,n,m) real f(0:8,0:n,0:m) !Streaming do j=0,m do i=n,1,-1 !Right to left f(1,i,j)=f(1,i-1,j) end do do i=0,n-1 !Left to right f(3,i,j)=f(3,i+1,j) end do end do do j=m,1,-1 !Top to Bottom do i=0,n f(2,i,j)=f(2,i,j-1) end do do i=n,1,-1 f(5,i,j)=f(5,i-1,j-1) end do do i=0,n-1 f(6,i,j)=f(6,i+1,j-1) end do end do do j=0,m-1 !Bottom to top do i=0,n f(4,i,j)=f(4,i,j+1) end do do i=0,n-1 f(7,i,j)=f(7,i+1,j+1) end do do i=n,1,-1 f(8,i,j)=f(8,i-1,j+1) end do end do return end subroutine sfbound(f,n,m,uo) !Boundary conditions real f(0:8,0:n,0:m) real uo !Boundary condition with known velocity at west wall do j=0,m rhow=(f(0,0,j)+f(2,0,j)+f(4,0,j)+2.0*(f(3,0,j)+f(6 ,0,j)+f(7,0,j)))/(1-uo) f(1,0,j)=f(3,0,j)+2.0*rhow*uo/3.0 f(5,0,j)=f(7,0,j)-0.5*(f(2,0,j)-f(4,0,j))+rhow*uo/6.0 f(8,0,j)=f(6,0,j)+0.5*(f(2,0,j)-f(4,0,j))+rhow*uo/6.0 end do !Bounce back on south boundary do i=0,n f(2,i,0)=f(4,i,0) f(5,i,0)=f(7,i,0) f(6,i,0)=f(8,i,0) end do !Bounce back on north boundary do i=0,n f(4,i,m)=f(2,i,m) f(8,i,m)=f(6,i,m) f(7,i,m)=f(5,i,m) end do !Open boundary condition at outlet do j=1,m f(1,n,j)=2.0*f(1,n-1,j)-f(1,n-2,j) f(5,n,j)=2.0*f(5,n-1,j)-f(5,n-2,j) f(8,n,j)=2.0*f(8,n-1,j)-f(8,n-2,j) end do return end subroutine rhouv(f,rho,u,v,cx,cy,n,m) !To find net rho and velocities real f(0:8,0:n,0:m),rho(0:n,0:m),u(0:n,0:m),v(0:n,0:m), cx(0:8),cy(0:8) do j=0,m do i=0,n ssum=0.0 do k=0,8 ssum=ssum+f(k,i,j) end do rho(i,j)=ssum end do end do do j=0,m do i=0,n usum=0.0 vsum=0.0 do k=0,8 usum=usum+f(k,i,j)*cx(k) vsum=vsum+f(k,i,j)*cy(k) end do u(i,j)=usum/rho(i,j) v(i,j)=vsum/rho(i,j) end do end do do j=1,m v(n,j)=0.0 end do return end !==========end of program=============== |
February 6, 2016, 06:58 |
Alex
Rep Power: 46 |
And what exactly is the problem with your code?
February 6, 2016, 08:21 |
Hamed Abdul Majeed
Rep Power: 13 |
The "u" velocity plot along the "y" direction shows the velocity to be zero...however, in actual it shouldn't!
February 6, 2016, 08:28 |
Alex
Rep Power: 46 |
Having a quick look at the code I spotted 2 obvious problems. I assume there are more.
1) You plot the velocity profile 300 lattice spacings away from the inlet after 20 time steps. Whatever you do at the inlet has not propagated that far after 20 time steps. 2) You initialize the velocity distributions functions with zero. That is quite unusual to say the least. Better use equilibrium values based on the macroscopic quantities. |
February 6, 2016, 09:40 |
Hamed Abdul Majeed
Rep Power: 13 |
Dear Alex,
Yes, when I changed the total time to 20000, the values turn out to be okay. And you were right about the whole domain setting to zero. Thank you. Regards |
February 6, 2016, 09:42 |
Hamed Abdul Majeed
Rep Power: 13 |
The FORTRAN file is available at:
http://1drv.ms/1SA7J5o |
December 13, 2016, 10:49 |
Jackie
Rep Power: 10 |
Hello , how do you choose the density and the nu?
Sent from my iPhone using CFD Online Forum mobile app |
April 21, 2019, 07:42 |
nusselt number by LBM
souhail souai
I'm working on the simulation of conduction and or convection radiation heat transfer in a 2D parallel channel by lattice Boltzmann method. when I tried to validate our code with a local nusselt number I have a disruption in some lasts values of nusselt. so I appreciate that you help us to explain or correct how to compute the nusselt number with LBM.
June 13, 2019, 17:08 |
#9 |
FARKACH YOUNES
You can find it in this book https:
//drive.google.com/file/d/15ZipkvhgK7MOP-RvoHNWQJ1w1ehTKgAS/view?usp=sharing |
SIMPLE BCs for flow in parallel plates | kabz | Main CFD Forum | 23 | September 21, 2015 10:31 |
Radial MultiPhase Flow between Flat Plates | deepaksaagar | Main CFD Forum | 0 | July 14, 2015 06:48 |
Possible to calculate the flow profile across flat plate? | midnightblack | Main CFD Forum | 1 | March 15, 2015 10:58 |
supersonic flow over flat plate | varunjain89 | Main CFD Forum | 1 | March 23, 2010 08:26 |
Flow Between Two Paralell Flat Plates | Stuart Cain | Main CFD Forum | 3 | September 28, 1999 08:21 |
