buying a commercial software to model free surface
Old   May 1, 2000, 00:03
Default buying a commercial software to model free surface
Michel Boufadel
Hi everybody,
I looking to buying a commercial software (get a licence) to model the following problem: 1) Put water in a 100 mL flask 2) Put the flask on a shaker that shakes the flask to and fro along one direction.
Note, free surface is present. Which software do you suggest? 1) Fidap 2) Fluent 3) CFX The first 2 have the Volume of Fluid (VOF) module that seems appealing. But it could be a marketing pitch.
Regards,
Michel
Michel C. Boufadel, Ph.D. Assistant Professor Environmental Engineering Temple University
Old   May 1, 2000, 00:10
Default Re: buying a commercial software to model free surface
turboguy
http://www.iccm.de
you will find out the strong capability of commnet s/w.
It is really strong in case of flow analysis including the free surface.
regards,
Old   May 1, 2000, 09:27
Alton Reich, PE
Michel,
I work for CFD Research Corporation, developers of CFD-ACE+. I recently finished a quick 2D demo of the sloshing of fluid in a tank due to seismic loads. We're expecting a PO to do the problem in 3D. I can send you a copy of the 2D animations if you'd like.
This particular simulation also included the stress in the tank structure along with the VOF free surface calculation.
Regards, Alton
Old   May 1, 2000, 19:37
Jim Park
Michel,
Can I recommend that you look at
http://www.flow3d.com/ ?
Flow-3d is the product of Flow Science Inc., the company founded and still managed by Dr. C. W. (Tony) Hirt, who invented the vof technique. They're located in Los Alamos, NM.
I have used Flow-3D for a variety of problems, including free surface simulations, and was very well pleased with the support I got from the staff. As you will see from their web page, they specialize in free surface solutions, including waves, ink jet simulations, casting, etc. The code was built from the start with free surface calculations in mind. They have a version of Flow-3d available to run on PC's as well as work station and main frame versions.
For the record, I am not related in any way to Flow Science, especially not financially.
Good luck!
Old   May 2, 2000, 06:34
Joern Beilke
If you really move you flask like in a shaker your free surface is destroyed an you get a lots of very small bubbles or foam. Then the VOF method might fail to produce usefull results.
Old   May 2, 2000, 10:16
Michel Boufadel
Thank you all. Regarding bubbles (and turbulence). I will start first with laminar flow. I understand that I will have to deal with turbulence and bubles later on.
Regards,
Michel
Old   May 3, 2000, 14:16
Shigunov
Yet another way is a direct density advection scheme. It seems me, such scheme is realized in the code COMET of Prof. Peric, Hamburg, Institut fuer Schiffbau. I am afraid, for bubbly flows this is the only way if it is impossible to follow dynamics of each bubble accurately.
With best regards
Free surface or Mixture Model ? Hervé CFX 10 December 29, 2014 13:29
Free Surface Model - Option Hannes CFX 0 August 20, 2008 05:19
Free surface model natesan Siemens 4 October 6, 2005 08:41
free surface calculations with the VOF model T.Waclawczyk Siemens 4 October 6, 2003 08:14
how to model a free surface lr FLUENT 5 December 8, 2000 07:51
