quires on turbulent viscosity
Old   June 5, 2000, 07:38
Default quires on turbulent viscosity
ram
i am new to this field of CFD. i have some small quires. 1. can we express the turbulent viscosity for 3D flow using prandtls mixing length model? if so how can it be expressed? 2. in k-e model for turbulence, if k is a function of x,y,z,t and similarly for e, dont u think it there should be 3 equations each for k and e, for complete mathematical closure of the model.?
Old   June 5, 2000, 08:47
Default Re: quires on turbulent viscosity
John C. Chien
(1). I think there is a popular algebraic turbulence model called "Baldwin-Lomax model", you can take a look at it. (2). If it is a function of x,y,z,t, then it is four dimensional. The variable is a function (x,y,z,t), and the equation will have derivative terms such as dkdx, dkdy, dkdz, and dkdt,etc.... (3). K and epsilon are not vectors, so each requires only one equation.
reversed flow at pressure inlet and turbulent viscosity is limited.... cfdiscool FLUENT 10 June 10, 2015 06:15
k-epsilon problem: non-physical turbulent viscosity production in coaxial free-jet Felipeb Main CFD Forum 1 July 26, 2010 17:02
Turbulent viscosity and shear rate shib FLUENT 0 June 22, 2010 12:44
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
