Troubles with MRF of a Mixing Tank
Like Tree2Likes
  • 1 Post By Guvennergiz
  • 1 Post By EngineeringStudent
Old   September 4, 2021, 06:09
Default Troubles with MRF of a Mixing Tank
Luke Anonymous
EngineeringStudent is on a distinguished road
Hello all,
I am trying to simulate the flow behaviour in a mixing tank, while I can get a solution, it is not what I expected. So, my impellors tip speed is 4.9 m/s (I am confident I have done this calculation correctly and also confident the radians/s I put into the frame motion was right). However when looking at my max velocity plot i have a considerable region above the impeller with a velocity magnitude greater than this (6.7m/s) . So my question is, am I wrong for thinking the tip speed should be the maximum velocity achievable?
Sorry I could not figure out how to add pictures
I'm not sure if this is useful but it is a 75mm Diameter (height = 10mm) 4 blade pitched blade turbine, rotating at 1250 rpm (130.9rad/s). I have all surfaces set as stationary no slip, (except symmetry condition for surface), am using k - omega sst, and have a maximum y+ only slightly above 1.
EngineeringStudent is offline   Reply With Quote
Old   September 4, 2021, 06:17
Luke Anonymous
Old   September 4, 2021, 09:32
Guvennergiz's Avatar
Guven Nergiz
Guvennergiz is on a distinguished road
Did you check the mesh dependency?
EngineeringStudent likes this.
Guvennergiz is offline   Reply With Quote
Old   September 5, 2021, 00:43
Default reply
Luke Anonymous
thankyou for your reply, after mesh independence I did see abit of improvement in my results! However it turns out this is normal by the looks of it, After looking at many papers I found one that has the same sort of maximum velocity position that exceeds the impeller tip speed. I suppose the low pressure zone behind the blade acts like the top of an aerofoil and speeds up the fluid or something.
Just incase in 5 years time someone is wondering the paper I was referring to :
https://www.sciencedirect.com/scienc...96890412002531
Thanks again mate,
Have a good one!
Guvennergiz likes this.
MRF steady state mixing time Swift FLUENT 0 August 11, 2016 05:14
Mixing Tank 3D MRF case monty86 FLUENT 1 October 9, 2015 03:43
Mixing tank with two phases Jana Fluent Multiphase 2 September 14, 2015 02:47
[DesignModeler] Modelling mixing tank using MRF approach Natali ANSYS Meshing & Geometry 0 March 17, 2015 06:26
Modelling mixing tank using MRF Adi FLUENT 6 November 4, 2009 00:28
