Help!!!!!!heat transfer over annular fin
Old   July 19, 2000, 12:02
Default Help!!!!!!heat transfer over annular fin
Dory Cano
First, sorry , I don't writting english good. I need information about how have the heat transfer over a annular fin, the boundary conditions are: solid for the annular fin, wall for the superficial of tube, and the boundary external, the environment, is the wall. My problem is: the Fluent create in the fin a : WALL AND WALL SHADOW, and for default are adiabatic, and the heat of transfer don't happen!!!
HELP IS URGENT!!!!!!!
Old   July 19, 2000, 14:19
Default Re: Help!!!!!!heat transfer over annular fin
Kai Kang
check fluent user's manual for wall-boundaries: the wall and wall shadow allows you to specify different heat transfer parameters for the two sides of the wall. You need to change the default
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
Calculate the heat transfer coeficient of a fin H Christos Siemens 4 February 23, 2009 16:56
ANNULAR FIN Dory Cano Main CFD Forum 1 July 20, 2000 00:25
annular fin HELP!!! Dory Cano Main CFD Forum 0 July 19, 2000 16:38
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
