July 13, 2000, 12:15 |
Compressibility of water
Hy,
I'm currently looking for values of the "compressibility factor of sea water", function of temperature and pressure Do you have something on the subject? Thanks |
July 13, 2000, 13:30 |
Re: Compressibility of water
A handbook of fluid.
Good luck |
July 13, 2000, 14:21 |
Or a thermodynamics book.
Adrin Gharakhani |
July 13, 2000, 21:27 |
Dear Dusart
Compressibility of water is fairly strong function of temperature. (And I remember that very weak function of pressure). You can find the value in the following text. J. P. Holman, Heat Transfer The approximate value under room temperature is (2~3)e-04 for pure water, depending on temperature, large at high temperature. Sincerely, Jinwook |
July 24, 2000, 07:08 |
The isentropic compressibility can be calculated from the sound-speed, the isothermal compressibility from the potential density. For sea water (and the oceanic pressure, temperature and salinity intervals) the standard reference is
Fofonoff, P. and Millard, R.C. Jr Unesco 1983. Algorithms for computation of fundamental properties of seawater, 1983. _Unesco Tech. Pap. in Mar. Sci._, No. 44, 53 pp. some of the algorithms have been implemented in MATLAB and can be found at the MATLAB-manufacturers site. regards Lasse Johansson |
Considering water compressibility !!!!!!!!!!!!!!!! | Bohis | FLUENT | 1 | November 2, 2007 17:56 |
Compressibility of water vapor ? | CFDtoy | Main CFD Forum | 1 | January 3, 2006 18:27 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
