Aerofoil data
Old   July 26, 2000, 01:03
Default Aerofoil data
Steve Collie
Hi, I am looking for a test case to validate turbulence models against. We propose to write a CFD package for flows past 2D downwind sail sections so I am really looking for a high-lift aerofoil operating in partially stalled conditions in a fully turbulent flow. Perhaps a NACA foil with high curvature and high angles of attack. The data I need is - Lift and Drag, Separation points and perhaps plots of pressure coefficient. If anyone knows were I could find this data it would be much appreciated.
Cheers.
Old   July 26, 2000, 05:12
Default Re: Aerofoil data
Sergei Chernyshenko
Click on Resources at the top of this page and then on Airfoils there.
Old   July 26, 2000, 16:01
Charles Crosby
You may want to take a look at some of the modern airfoils designed for slightly bizarre special conditions. The one I tried to do an analysis of is the Selig S1223 - it is so highly cambered that there is nearly always some separation present, so the operating conditions are somewhat similar to a downwind sail. It's not an easy CFD problem. XFoil (2d panel method & boundary layer code) would normally be one's tool of choice for low Reynolds number airfoils, but it was extremely difficult to get converged results on this problem. Agreement with a 2d unstructured Navier-Stokes code using Baldwin-Lomax turbulence model was rather poor. I think that the Stuttgart profile catalogue may have some experimental results on an airfoil for human-powered flight, once again, I think that is a similar operating condition, although the flow is unlikely to be very turbulent. The other area worth exploring for validation cases may be wind-turbine blades - apparently this flow is normally fully turbulent, due to the abrasion on the leading edges of the blades.
Charles
【Help】"Error: Update_Time_Level: invalid data" Chen FLUENT 2 August 24, 2014 07:51
export data at nodes Meenu FLUENT 1 December 30, 2011 01:24
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
CGNS vs Tecplot Data Format LWhitson2 Main CFD Forum 3 July 1, 2011 13:50
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
