volumetric conservation equation in PHOENICS code |
July 29, 2000, 13:50 |
In case of the two methods HOL and SEM implemented in PHOENICS code for simulating free surface flows, the continuity equation was formulated in term of volumetric conservation as D(Ln(RHO))/Dt+du/dx+dv/dy+dw/dz=0.
REF: Free surface flow and heat transfer in cavities: the sea algorithm K.A Percilious & al 1995 Numerical heat transfer Part B, 27:487-507, 1995 1- what are the steps followed to discretise this equation by finite volume method ? 2- What is the discretized form of this equation ? Thank you. Hydraulic and Environemental Modeling Laboratory National Engineering School of Tunisia |
July 29, 2000, 19:14 |
Re: POST THE CODE RELATED MESSAGE IN RIGHT FORUM
(1). The code related message should be posted in the code specific forum, not in this main forum. (2). You should find the right one at the first page of the forum.(3). For code internal structure, it is a good idea to talk to the vendor directly. Send the e-mail to them.
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
UDS for charge conservation equation | Manoj | FLUENT | 0 | February 7, 2008 04:49 |
continuity equation | Rafal | Main CFD Forum | 4 | November 29, 2006 09:27 |
Use of an hydrodynamic model integrated in the vertical by the PHOENICS code | Hafsia Zouhaier | Main CFD Forum | 2 | March 15, 1999 08:23 |
