pressure drop
Old   September 29, 2000, 10:27
Default pressure drop
Francisco Saldarriaga
Fluid world: What is a practical way of increasing pressure drop to avoid-reduce pulsations in the rate of fuel or air supply, or both in a combustion process? The objective is to have a meanful pressure drop through the supply system so the downstream pressure have little or no influence on the flow rate.
Old   September 29, 2000, 11:10
Default Re: pressure drop
John C. Chien
(1). If you have an old car, the oil pressure (difference) will be low due to larger gap through the bearing system. (2). In this case, you can replace the bearing, and/or the oil pump to reduce the gap thickness. (3). Or you can use thicker oil or oil additive to increase the viscosity of the oil. (4). Using the same principle, you can: reduce the diameter of the pipe at the downstream side, before entering into another device (injector or something which you didn't say). (5). Or you can change the property of the fluid (fuel) by increasing the viscosity level.
Old   September 29, 2000, 12:13
Evan
Why don't you just install some throttle valves upstream of your combustion chamber? You would be able to adjust the pressure drop and, if far enough upstream, without increasing turbulence in the chamber.
Old   September 29, 2000, 23:23
sameer mohrir
Hello Francosco Saldarriaga
You can use Pressure Reducing valves to reduce pressure of any fluid.
regards
Old   September 29, 2000, 23:31
Chung Kuo
It is interesting you mention this pressure drop to overcome the pulsation due to discharge at downstream. Usually, as I konw, extra volume of damper or resovior is added to smooth the pressure wave. Restriction has the damping effect, but the pulse is the way for the discharge to continue. The pulse should be compensated, but not be restricted. or, I missed your point.
pressure drop in the pipe mike.mm FLUENT 6 February 7, 2011 10:31
Pipe Flow - Pressure Drop Daniel L FLOW-3D 2 December 10, 2010 04:23
Total and static pressure drop Janakiram Siemens 1 February 8, 2009 01:32
Pressure Drop at entrance of a rotor-stator. Resnick Main CFD Forum 0 November 20, 2007 14:50
Periodic boundaries and pressure drop MatejK CFX 2 July 12, 2005 04:47
