irrotational, incompressible flow
Old   October 3, 2000, 20:49
Default irrotational, incompressible flow
Mark
Here is the question: The height of the fluid in an upright circular cylinder of radius, r0, is maintained at a constant value, H. The fluid spills from the bottom of the cylinder through a cylindrical slit of height, h0, and radius, r, from the axis of the cylinder. Obtain an expression relating h/h0, r/r0 and the constant h0/H.
-The height H is the overall hieght from the surface to the top of the fluid. -The h0 is the height between the surface and the bottom of the cylinder. -The r0 is the radius of the cylinder -The h is the height of the fluid at a distance r from tne center of the cylinder.
Assumptions: -The flow is driven by gravity -The flow is irrotational and steady -All fluid particles priginated at the top of the column of water which is at atmosperic pressure and the fluid speed at this level is negligible compared with the fluid speed near the supporting plane -The radial velocity in the spreading fluid varies only with r.
Please inform how to solve for objectives.
Thanks in advance
Old   October 4, 2000, 15:18
Default Re: irrotational, incompressible flow
ZEBDI
je veut une documentation sur : l'écoulement d'un fluide incompressible dans regime laminaire permanant autour d'un cylindre fixe ou en rotation. - Calcul des isovitesses - Calcul des isothermes - Calcul de coifficient de frottement - Calcul de coifficient de transfert de chaleur.
Can CFX be configured for incompressible flow? Dr. Bian CFX 8 May 3, 2006 09:58
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
pressure outlet BC for incompressible flow khaiching Main CFD Forum 6 October 15, 2005 02:58
Incompressible and compressible flow. John. Main CFD Forum 1 December 15, 2004 11:29
incompressible flow - prescribing pressure drop - how best to do it? M. Gerritsen Main CFD Forum 4 January 10, 1999 09:53
