1D Internal Flow
Old   November 1, 2000, 12:49
Default 1D Internal Flow
Morten Haug Emilsen
I am currently performing a research in the CFD forums to find a way to model the transient flow in a pipe (only 1D) with different boundary conditions. (These can be closed, pressure given or a choke at the outlet.)
My problem is a pressurized pipe (closed in both ends) with a leakage somewhere along the pipelength. My question is? What will the flowrate be out of the pipe as function of time, and what will the flowprofile in the pipe be, (pressures and flowrates) and how long does it take to empty the pipe?
The fluid inside the pipe is liquid with density as function of pressure and temperature. I guess I have to take wall friction into account.
Can you give me some ideas of where to start. I have looked at the SIMPLE and SIMPLER algorithms, can they be used, and where can I find the source codes. (I have the Patankar book.)
Thanks, Morten
Old   November 2, 2000, 06:26
Default Re: 1D Internal Flow
Sergei Zhubrin
The problem can be easily modelled by PHOENICS shareware, which has 1D/2D/3D, compressible/incompressible,steady/unsteady, onephase/multiphase solver.
The relevant source codes are GENMIX 2P and 2/E/FIX-CHAMPION. The latter is, actually, 2D (SIMPLE) code but can be easily reduced to handle 1D problems.
The references to start are CFD83/4 and HTS81/8.
Regards
Sergei Zhubrin
Advice on turbulence model for complex internal flow JPBodner Main CFD Forum 1 September 3, 2011 03:07
Velocity at wall in an internal flow rsmartins CFX 3 July 16, 2011 06:58
Internal error in compressible flow be density Mirek FLUENT 0 August 20, 2008 08:59
Why Re is diff for external and internal flow? john Main CFD Forum 1 June 13, 2007 02:58
Boundary conditions for internal flow lavan Main CFD Forum 2 November 4, 2004 13:36
