Higher Order FV Schemes for unstructured meshes
Old   December 14, 2000, 00:08
Default Higher Order FV Schemes for unstructured meshes
Apurva Shukla
I am looking for higher (2nd and above) order FVM for unstructured meshes, esp. triangular. Most of the reference I have are for structured meshes. I am more interested in N-S solvers.
Thanks & Regards Apurva
Old   December 14, 2000, 12:26
Default Re: Higher Order FV Schemes for unstructured meshe
frederic felten
hi there,
Take a look at the following publication:
"Conservation Properties of Unstructured Staggered Mesh Schemes." Blair Perot. Journal of Computational Physics, Vol 159, pp 58-89, 2000.
I hope this helps, Sincerely,
Frederic Felten. CFD Laboratory, UT Arlington. http://utacfdb.uta.edu/
Old   December 15, 2000, 05:25
Rajeev
Hi Apurva:
Firstly i would like to reply on your query. For a cell-centered, finite volume upwind scheme, higher-order accuracy can be achieved by a multidimensional linear reconstruction process. In higher order formulation, you have to calculate solution-gradient at the cell center. In 2D, this will be nothing but line integral around some closed path around the cell center.
I have used the above reconstruction process and Van Albada type Limitor in my unstructured (Triangles) Navier Stokes code. If you want, I will send my document and formulation for the same.
I think, you are working in Fluent India. I will write separately on the personal issues.
Cheers
Regards Rajeev
Old   December 15, 2000, 05:59
Apurva Shukla
Hi Rajeev,
You guessed it right I am in Fluent India. If you have a soft copy of your report, can you mail it to me at : as@fluent.co.in. Will write to you soon on personal issues.
Regards Apurva
Old   December 15, 2000, 09:17
Kang, S. K.
I don't know what kind of PDE you want to solve. If you want to solve hyperbolic equations, I think there are some choices. ENO, WENO, MUSCL or PPM can be the choice. These have 2nd or 3rd order accuracy.
Triangle Based Adaptive Stencils for the Solution of Hyperbolic Conservation Laws, Journal of Computational Physics, Vol.98, pp.64-73, (1992)
Multidimensional Slope Limiters for MUSCL-Type Finite Volume Schemes on Unstructured Grids, Journal of Computational Physics, Vol.155, pp.54-74, (1999)
Weigted Essentially Non-oscillatory Schemes on Triangular Meshes, Journal of Computational Physics, Vol.150, pp.97-127, (1999)
Good Luck~!
Volume 10 has higher order elements Duncan FLUENT 0 November 2, 2005 13:52
Higher order discretization on staggered grid Chandra Shekhar Main CFD Forum 9 January 27, 2005 16:31
Gradient Estimation for Higher Order Schemes jianxia Main CFD Forum 0 June 6, 2000 19:40
LES - numerics David Hunt Main CFD Forum 8 May 23, 2000 02:08
TVD/ENO schemes for anisotropical meshes Matthias Bartel Main CFD Forum 0 August 5, 1998 04:18
