Remeshing Algorithms
Old   January 11, 2001, 08:36
Default Remeshing Algorithms
Apurva Shukla
I am looking for algorithms in which I change the grid completely for each time-step or after some particular time step. Are their any refrences available which give the interpolation techniques for assigning the values to new cells based on solution from previous time step. I hope I am clear in explaining my problem.
Thanks
Apurva
Old   January 14, 2001, 04:16
Default Re: Remeshing Algorithms
John C. Chien
(1). You need to take a look at the "Adaptive Meshing". (2). In Joe Thompson's book "Numerical Grid Generation", there is a chapter XI on "Adaptive Grids".
Old   January 18, 2001, 00:41
A. Rajani Kumar
How you are going to change the grid. 1)Is it is based on gradients of the flow charecterstics then u refer adaptive grid generation. 2)if you are changing the grid size it self which is comman in the case of Multigrid methods then refer MG net. 3)If it a moving grid i mean with grid is depend on time then you have to see fluid dynamics and geat tranfer of turbomachinary by Lakshminarayana, Budugur
But unless u clearly tell how your grid is a changing with time, it is very difficulat for any body to gine exact answer.
Old   January 18, 2001, 01:48
Apurva Shukla
There are two information I am looking for :
1. First change in grid due to gradiant adaptation, preferably remesh the whole domain.
2. Remeshing as in cases of moving valves of IC engines, where mesh changes in every time step and you have to get the values at new cells for next time step.
As far as moving grid are concerned I have already worked on 3-D structured Euler solvers for multistage turbomachine, so I have no doubt regarding it.
Thanks for your help
Regards Apurva
Remeshing with User Defined Options ChristianF CFX 2 September 24, 2014 09:19
Bugg in Remeshing in 3D - Any Fluent Wizards ?? Amr FLUENT 1 November 1, 2011 04:04
FSI with remeshing omidiut CFX 3 September 12, 2011 17:01
Dynamic mesh (local remeshing) I'm stuck Mike FLUENT 2 February 26, 2006 14:00
Dynamic Grid Remeshing causing Divergence? Andrew Wick FLUENT 0 January 23, 2006 18:39
