DNS and LES?
Old   January 23, 2001, 12:41
Default DNS and LES?
Junseok Kim
Hi, I wonder what those are?
DNS and LES?
Are there any easy references for those?
Thank you~
Old   January 24, 2001, 04:09
Default Re: DNS and LES?
sylvain
DNS = Direct Numerical Simulation; LES = Large Eddy Simultion
For DNS you solve exactly the Navier Stokes equations in time and space. That's mean you have to use a grid fine enought to catch all the scales of the turbulence.
For LES, only large eddies are solve and dissipative effect of small scales is usualy modelize throught a viscosity (SGS model = Sub-Grid Scale Model).
You may look to the following article :
P. R. Spalart - 1999 - Strategies for turbulence modelling and simulations Engineering Turbulence Modelling and Experiments 4 - W. Rodi and D. Laurence (Editors) - Elseviers
It gives a good introduction to the different ways use to solve the turbulence problem in CFD. The bibliography of this paper may give you some indication about references you are looking for.
Sylvain
Old   January 24, 2001, 12:23
frederic felten
hi there,
check the following link: http://www.ionasoftware.com/gross/fl...urbulence.html
you'll find all the info you need about DNS & LES.
you can also go to Ugo Piomelli's publications website: http://www.glue.umd.edu/~ugo/research/publications.html
you'll be able to download a lot of papers and more about DNS and LES.
Sincerely,
Frederic Felten CFD Lab, UT Arlington. http://utacfdb.uta.edu/
Old   January 26, 2001, 01:06
Default thanks
Junseok Kim
Thank a lot, it is a great help.
Mesh size for DNS and LES Glenn Horrocks Main CFD Forum 45 May 25, 2020 15:43
doubt about DNS and LES of combustion chinthakindi Main CFD Forum 5 August 17, 2013 11:56
DNS and LES resolution Larsen Main CFD Forum 0 November 25, 2010 18:10
Need help for DNS and LES methods Paul Main CFD Forum 1 August 12, 2003 07:22
Laminar solver? LES? or DNS? Ray Main CFD Forum 5 March 19, 2003 10:19
