flow over a 2D cyl using SIMPLE
Old   January 24, 2001, 13:23
Default flow over a 2D cyl using SIMPLE
T
Hi everyone
Although the original SIMPLE formulation was through finite volume, I believe that the SIMPLE algo can also be used for a finite diff. formulation provided the equations used are in the conservation form, which are derived by considering a fixed infinitesimal fluid volume in space.
I would like to know what the important considerations are while using a finite diff. formulation for SIMPLE and also if a non conservation form of equations can be used. Say for e.g. if I were attempting to solve the incompressible flow over a 2D cylinder using a polar grid using SIMPLE, would I have to consider the conservation form of the transformed N-S equations?
Any advice would be greatly appreciated. Many tanks in advance.
Old   January 27, 2001, 07:32
Default Re: flow over a 2D cyl using SIMPLE
Senthil
1.For this particular problem you need not use the transformed equations.You can solve it premitive variables it self. You say u r using finite difference scheme Simple will work . Just Discretise the N.S ( premitive variables will do)and try it out.
blasius flow simulation using SIMPLE method sizyef Main CFD Forum 1 December 18, 2011 10:49
Ask help wiht a SIMPLE Method on compressible flow. universez Main CFD Forum 0 February 8, 2010 10:38
two flow heat tranfer in the simple heater flow1025 FLOW-3D 1 December 31, 2009 19:45
Strange Solution for a simple pipe flow!! shekharc Main CFD Forum 4 May 9, 2005 09:21
SIMPLE method for 2-D flow N.Natiq Main CFD Forum 0 June 2, 2001 08:26
