Hydraulic pump -3d simulation paper
Old   March 30, 2001, 10:03
Default Hydraulic pump -3d simulation paper
ken elms
Can I recommend this paper to those showing CFD interest in 3D-hydraulic pumps[radial,mixed axial flow]. SIMULATION OF 3D UNSTEADY FLOW IN HYDRAULIC PUMPS http://www.ub.utwente.nl/webdocs/wb/1/t0000004.pdf
Old   April 2, 2001, 02:56
Default Re: Hydraulic pump -3d simulation paper
John C. Chien
(1). Thank you very much for the information. (2). I think it is a very good piece of work, both theoretical and experimental. (3). Since I don't have the time to read the whole report on line,I will try to find time to download and read it.
Old   April 2, 2001, 04:19
John C. Chien
(1). Figure 6.28 Eta vs Q shows clearly the difference between the idealized model and the real world data. (2). In real world, the flow is always 3-D turbulent, and most likely transient. At the design point (or BEP), the flow is less complicated and thus a better match is achieved. At the off-design point, the loss model is not accurate because the base model is very complicate. (3). The value of the paper is in its careful approach in numerical modelling, comparison with experimental data, and the identification of the differences.
Vacuum pump simulation Alasdair Main CFD Forum 3 March 3, 2011 00:00
Multiphase fluid pump simulation jorge CFX 1 September 9, 2007 18:27
Side channel pump simulation mohammad CFX 0 June 3, 2007 11:16
Pump Simulation wak Siemens 1 November 3, 2004 23:58
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 10:06
