fluid-structure interaction
Old   June 28, 2001, 12:48
Default fluid-structure interaction
Tikka
Hi, I am trying to simulate the flow around a vibrating cantilever immersed in incompressible viscous fluid. I would highly apprectate if anyone working with similar problems could provide me with some references. Thanks. T
Old   July 3, 2001, 15:55
Default Re: fluid-structure interaction
Dimitri
We have been doing quite a few FSI simulations with our code RADIOSS-CFD. You can check the exemples on our web site www.radioss.com under the M-Explicit applications pages.
Old   July 5, 2001, 20:03
Ramadan Bassiouny
The finite element method is a strong tool to handle such a problem. If you have an access to ANSYS 5.4 or 5.5 package, it will handle your problem. Their web site is www.ansys.com. In ANSYS, they have a fluid solver called FLOTRAN. You can solve for your fluid flow using FLOTRAN and then transfer the resultant pressure as load on your structure and solve for the deformation using ANSYS/Structure discipline. I know that they have an educational version which can handle up to 1000 elements. All waht you need is to generate your grid and write an external macro which will take care of the solution process till the convergence. Good luck.
Old   July 7, 2001, 14:08
Peter
Yes, you can solve the fluid-dynamic problem with FLOTRAN, and then extract the pressure distribution on the wall and run the structural problem, but what do you mean with that macro? can you be more explicit? Thanks
Old   July 7, 2001, 15:08
Peter Attar
Here is an example of what he means: http://www1.ansys.com/customer/conte..._G_COU2_9.html
Fluid structure interaction on baloons vinz OpenFOAM Running, Solving & CFD 38 September 14, 2016 12:38
Fluid Structure Interaction using icoFsiFoam Problems lr103476 OpenFOAM Running, Solving & CFD 79 August 7, 2014 09:30
Optimization or fluid structure interaction Steve_NTUA Main CFD Forum 9 August 29, 2006 03:40
Fluid structure interaction tomm FLUENT 2 September 16, 2004 04:33
Fluid Structure Interaction Gabor Balint FLUENT 2 January 5, 2000 13:08
