Multigrid and Jacobian
Old   July 19, 2001, 13:13
Default Multigrid and Jacobian
biga
I'm working with an FDM method and implementing an FAS MG. I would like to know how should I treat the Jacobian of the mesh when restricting and prolongating. I store the Jacobian-scaled properties.
Currently, I descale the properties to restrict and then scale again by the new mesh Jacobian. However, the same does not go with the residue. Is it right?
There would be any hint regarding the problem of the Jacobian of the mesh transformation?
regards
Old   July 25, 2001, 17:31
Default Re: Multigrid and Jacobian
Junseok Kim
What kind of equations do you use for simulation?
Old   July 25, 2001, 23:08
biga
Hi, I am using an explicit, 2nd order, 3-D finite difference algorithm, with central differences. Artificial dissipation is calculated using the scalar Turkel&Vatsa model. This code is used for rocket-like configuration applications and solves Euler or laminar NS. Boundary conditions include: far field, exit, center-line averaging and solid wall 1st-order extrapolation.
Best regards,
Biga
Multigrid on FDM Enda Bigarelli Main CFD Forum 9 July 13, 2001 10:45
