August 16, 2001, 15:21 |
SIMPLE Boundary Conditions
If I use the staggered grids and have the half control volumes on the boundary
1.) Would I be putting in some guess values of pressure at that boundary although P correction has to be zero. 2.) Moreover if I specify the guess pressure at the boundary my normal velocity face at that surface and the press. node coincide. Should that be a problem. Do higher Reynolds number (>500) pose a problem if I have a pure iterative scheme (Gauss -Siedel) of solving the equations. Any books as to how to treat the boundaries except for Patankar and Peric as I am not too sure how to specify the velocities and pressure at the boundaries. Thanks in advance. |
August 17, 2001, 08:20 |
Re: SIMPLE Boundary Conditions
Usual BC for incompressible flow:
1) Normal velocity imposed (such as on a wall or at an inlet) : derivative of the correction of pressure will be such that the final velocity will agree with the normal velocity (neumann BC for correction of pressure) 2) Pressure imposed: Dirichlet BC for pressure correction. Neumann BC for velocity (usually zero at an outlet). |
August 19, 2001, 22:57 |
Kunal, Is the question like this: "I use SIMPLE with staggerred grid. What are the bc's for momentum equations? What are the bcs for the p' eqn? Are they compatible, even if I use the half cvs (Patankar's approach 'B')?"
August 20, 2001, 09:58 |
Mukhopadhyay, Pretty much. And I am not too sure as to how to implement these conditions on the grid. Like how should I be constructing my grid.
Questions about the inletOutlet and outletInlet boundary conditions | brooksmoses | OpenFOAM Running, Solving & CFD | 24 | March 2, 2021 01:16 |
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 12:58 |
non reflective boundary conditions for incompresible flow | Pascal_doran | OpenFOAM Programming & Development | 16 | August 25, 2015 05:35 |
Help with boundary conditions | Dan | CFX | 0 | April 3, 2006 11:32 |
