WET SCRUBBER simulation
Old   September 7, 2001, 14:48
Default WET SCRUBBER simulation
LOUCHE
Hello, I am looking for a software that allows to modelize spray column used for desulfurization. These columns work with water and gaz that contains SO2. Cheers.
Chris.
Old   September 9, 2001, 06:16
Default Re: WET SCRUBBER simulation
alain
Hi chris,
you may use different software for wet scrubber simulation.
Your choise will depend on :
1/ what you exactly want to take into account (particle trajectories, SO2 adsorption, wall inpregnation) depending on the purpose of you simulation
2/ The budget you have for buying the software.
Best regards
Old   September 10, 2001, 04:51
Christophe Louche
Thanks for your answer, What I really need is a software that can describe the SO2 absorption in a dropplet that contains lime. This software, of course, should be the less expensive as possible.
Chris.
Old   September 10, 2001, 10:02
alain
Dear Chris,
In your wet scrubbler problem, there are several point which can be more or less critical depending on geometry and what you are looking for :
1/ flow field,
2/ particles trajectories with or without wall impigment
3/ SO2 adsorption on droplets
4/ Heat transfert, ...
if you think that every thing is important you should look at a high cfd software. I never used it but I heard that CFX perform well for multiphase simulation. Fluent can also do the job but you will need User Defined Fonction for SO2 adsorption. Nevertheless this approach will be long and costly.
If deal essentially with point 1 and 2 a low end softawre package such as FloWorks for example can do the job. In this case you will have to postprocess Adsorption.
If point 3 is the most important but you can make assumption on flow field you may considerer to develop your own program in order to take into account particle trajectories and adsorption
At last, depending on you position, if this need is ponctual you may consider to hire a consultant.
I hope this could help you. Let me know more on you application and I may help you further on your software choice.
Best regards
Alain FRYDMAN
Old   September 10, 2001, 16:50
p. fortuijn
Femlab (Finite Element Method, Matlab-add-on) can do flow, heat transfer and physical chemistry processes like adsoprtion quite easily (Points 1, 3 and 4). Never worked with it but I have seen it working.
You can check out www.femlab.com
Cheers, P.Fortuijn
Old   September 11, 2001, 05:13
Christophe Louche
Hi Alain, In fact, I have actually done a simulation of the flow field in a wet spray scrubber of 35 meter high on Fluent. It shows interresting phenomenon like a great rotation of the gas in the scrubber. Secondly, when the calculus was converged, I have done a "particles tracks" to visualize the particles trajectories in the scrubber. The bubble was considered as a little ball with no heat and mass transfer. Now, my problem is to modelize the mass transfer of SO2 between a droplet of water that contains lime and the gas. I want the simplest model as possible but the main difficulty is to know the K and [SO2]i in the mass transfer equation : N = K ([SO2] - [SO2]i). Best Regards. Chris Louche.
Why my simulation not agree with the wind tunnel experiment zhaowei CFX 4 July 11, 2015 03:36
Axial fan simulation in UG/NX 7.5 fan123 Main CFD Forum 2 April 23, 2011 08:22
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 10:44
GUI crash and simulation engine still running RPJones FLOW-3D 2 November 9, 2010 08:18
velocity profile export from a simulation onto another sudhirlv STAR-CCM+ 1 September 12, 2010 18:57
