checker board at free-surface
Old   September 17, 2001, 06:56
Default checker board at free-surface
name
at free-surface interface... because of defferent density, vertical directional velocity (3D) distribution has checker board problem. my scheme is SIMPLE, HRIC, ... Can I fix that ?
Old   September 17, 2001, 12:01
Default Re: checker board at free-surface
Mr. Babble
What is your density ratio. Are you using a conservative or non-conservative form of the equations. Are you using surface tension? Is it large?
If you look at your pressure correction equation and you see that you have density within it, there is a way to take it out. Just derive the pressure correction equation and try and cancel out the density. It will.
This may be only half your problem. I don't really know. At free surfaces the surface tension force puts a discontinuity in pressure. If you have a good discontinuous coefficient solver than you should be ok. I.e. maybe multigrid. If not then your solver will try and smooth out your pressure discontinuity and place the discontinuity on the velocity field. To solve this , well I don't know, but my best quess would be to look at the solver. Ie. throw out stone
Free surface is below than expected..results are not good mechovator CFX 24 April 8, 2011 00:41
Can Flow-3D plot the free surface area in Iso-surface or colour variable? therockyy FLOW-3D 1 June 20, 2010 19:36
Submarine Free Surface samwh CFX 7 August 30, 2009 07:14
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 18:13
Modeling Free Surface Flows Elliot Schwartz Main CFD Forum 5 August 25, 1998 21:03
