Grid generation package confined to turbomachinery
Old   September 4, 2001, 14:10
Default Grid generation package confined to turbomachinery
Lee
Dear collegues.
I am calculating tip clearance flow in axial type turbomachinery. Because I used the low Reynolds number turbulence model, very dense grid with clustering near the wall is needed. I tried to generate mesh bu using commercial package, but I could not obtain any satisfactory results. Therefore, I determined to order the package and, if possible, please let me know your suggestions.
Thank you
Old   September 4, 2001, 16:39
Default Re: Grid generation package confined to turbomachi
Joern Beilke
If you need a high quality (hex) mesh with suitable spacing at the wall then you should have a look at GridPro.
Old   September 5, 2001, 05:40
Peter
There is also Tiger from Catalpa. You can download even a demo online and test if it is suitable for your application
Old   September 5, 2001, 08:29
Remy Tasse
IGG/Autogrid from NUMECA can certainly help you. This meshing tool is specifically dedicated to turbomachine and tip clearance modelisation can be performed.
Old   September 5, 2001, 10:04
Remy Tasse
The meshing tool IGG/Autogrid from NUMECA will help you a lot. It is dedicated for meshing on turbomachines and affords to modelize tip clearances.
Old   September 5, 2001, 17:38
p. fortuijn
TascFlow from AEA Technology is designed for turbomachinery.
Old   September 6, 2001, 05:34
David
You could also look at ICEM CFD HEXA. For more info see,
http://www.icemcfd.co.uk
Or email me
davidm@icemcfd.co.uk
If you have more detailed questions.
Regards
David ICEM CFD Engineering
Old   September 18, 2001, 12:33
Shyam Kishor
"G/Turbo", a new preprocessing tool from Fluent is specially designed for Turbomachinery applications. It allows modeling of Tip clearances, and generates high quality mesh with nice boundary layers.
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 03:33
elliptic grid generation prapanj Main CFD Forum 1 November 19, 2007 16:53
3D Hyperbolic Grid Generation - Help Requested... Marcus Lobbia Main CFD Forum 2 November 9, 2003 05:53
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
Latest news in mesh generation Robert Schneiders Main CFD Forum 0 March 2, 1999 04:07
