December 14, 1998, 03:24 |
Turbulence Intensity Vs CFD Simulation
Turbulence intensity of a point inside space can be obtained by using measured velocities of that point varied with time. However, in CFD simulation, only steady state results of velocity, temperature, pressure, turbulence kinetic energy and dissipation rate of turbulence kinetic energy are calculated. Could anyone please tell me if there is any direct relationship/equation linking turbulence intensity and CFD simulated results, i.e. can I use the CFD simulated results to calculate or estimate the turbulence intensity at any point of the indoor space.
Thank you! |
December 14, 1998, 03:40 |
Re: Turbulence Intensity Vs CFD Simulation
At first, for me turbulence intensity and turbulence kinetic energy are the same so it would be fine if you define what you mean by turbulence intensity. Second, I am not sure that measuring turbulence intensity at a specified location at a specified time will give useful information. You need mean values in order to compare efficiently different approaches to study turbulence. Therefore it seems to me that only "mean (in time or in space or ...) turbulence intensity" (rms of the velocity fluctuations) deserves to be measured and compared to theory or numerical computations. And this quantity (the rms of the velocity fluctuations) can in principle be found using classical CFD tools. Hope it helps, Gary |
December 14, 1998, 03:48 |
If I may, I'd like to add this : with CFD you do not only get steady states !! You can run temporal simulations (time-marching) of unsteady phenomena, with either RANS or DNS/LES approaches. It is then possible to carry out local spatial averaging of flow variables at each time step, thus obtaining an "average" and a "fluctuating" velocity field, which allow you to define a form of turbulent kinetic energy. It is also theoretically possible to carry out spatial simulations (marching in space instead of in time) and you can then carry out your time-averaging process just like in the "classical" definition of stochastic averaging in the "turbulent" Navier-Stokes equations. Hope I was clear enough !
Fabien |
December 15, 1998, 17:28 |
For fully developed pipe flows the turbulent intensity at the core can be estimated by I = 0.16 (Re)^-1/8
CFD Salary | CFD | Main CFD Forum | 17 | January 3, 2017 17:09 |
High turbulence intensity | wenfengxie | FLUENT | 1 | April 16, 2010 12:00 |
turbulence intensity for skyscraper | antonella grassano | FLUENT | 0 | October 13, 2004 06:50 |
Reactor simulation using CFD takes to the Internet | Mark Brennan | Main CFD Forum | 0 | April 16, 1999 05:57 |
CFD - Trends and Perspectives | Jonas Larsson | Main CFD Forum | 16 | August 7, 1998 16:27 |
