January 11, 2002, 04:05 |
Solid Boundary Condition
I am working on a computation in which solid boundary condition should be used. Because several layers of ghost points will be added artificially on the boundary, I wonder how to determine their values according to the known values of the flow field. p.s. My problem is about compressible inviscid flow.
Any comment is welcome! Yours Sincerely Zhang Lei |
January 11, 2002, 06:31 |
Re: Solid Boundary Condition
I don't know what method you used. In general, you have discretised equation look like:
A_cell * PH_cell = sum (A_neighbour * PH_neighbour) + source For solid cells: just set A_cell=1.e+25 (a big number) and source=0. so that the solver will give PH_cell=0. You have to treat the boundary between these ghost cell and real fluid cell as proper wall. |
January 11, 2002, 07:27 |
Hi, Seems that you are dealing with compressible Euler system or something similar. If that's the case, solid boundary should be reflective boundary. Hence, you just inverse the velocity perpendicular to the boundary and keep all the other values.
January 11, 2002, 13:03 |
respectful li,
hello i am prasaath from india. i am a mechanical engineering student. do u have anything to say to me as i know very little about CFD . mail me back. yours sincerely s.prasaath |
January 12, 2002, 17:27 |
Ask Jamson ...
Hu ... |
mixed inflow/outflow downstream boundary condition question | peob | OpenFOAM Running, Solving & CFD | 3 | February 3, 2017 10:54 |
how to set up a wall boundary condition according to calculated wall shear stress? | gameoverli | OpenFOAM Pre-Processing | 1 | May 21, 2009 08:28 |
increasing mesh quality is leading to poor convergence | tippo | CFX | 2 | May 5, 2009 10:55 |
How To Convert Fluid wall in Solid Wall Boundary Condition | RGN | FLUENT | 4 | March 31, 2009 04:43 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
