About filtering process in LES
Old   January 29, 2002, 01:38
Default About filtering process in LES
Yang
Hi, friends:
I just came across a problem in my research on Large Eddy Simulation. For my code of LES, I used to use implicit filter for my grid level filtering, which actually is no filtering at all. Now I wanna use a new explicit filter, does that mean I should filter the solution at each time step. However, I do notice that after applying the filter to the N-S equations, what I solve for are the resolved variable. Is it correct for me to filter the resolved quantities again and again at each time step? I just feel confused about this point. Can anybody give me some guide with his experience or some reference? Thanks a lot.
Old   January 29, 2002, 10:58
Default Re: About filtering process in LES
Rajani Kumar Akula
Hi yang,
when you use so called implicit filter, you will not bother about the type of filter you use. because implicit filter is just a averaging process. but when you use explicit filter then u have to bother about the filter type you want to use. Due to explicit filtering sub grid scale terms are depends on the type of the filter u use. refer CTR-standford papers for more clarification. bye rajani
Old   January 29, 2002, 13:46
Yang
Thank you, Rajani. I will follow your suggestion.
LES (explicit) filtering John Main CFD Forum 2 July 29, 2004 18:03
Another LES filtering question Tim Main CFD Forum 2 December 10, 2003 13:30
Filtering technique for LES K.K.J.Ranga Dinesh Main CFD Forum 0 July 2, 2003 22:47
Dynamic filtering for LES Takuya TSUJI Main CFD Forum 1 July 14, 1999 02:17
Channel LES and explicit filtering Luca Liberti Main CFD Forum 0 January 17, 1999 10:07
