Poisson eq. with Chebyshev collocation
Old   March 5, 2002, 01:09
Default Poisson eq. with Chebyshev collocation
Paul
Dear all, I am trying to solve Poisson equation with Chebyshev collocation method. It is essentially a direct method, via two multiplications on the eigenvetors. However, I can only solve it with following b.c (in either direction)
1) Both Dirichlet 2) One Dirichlet and one Robin\
For Neumann conditions, I always fails. If anyone has experience in this topic, please kindly provide your comments.
P.S. from this link http://www.math.psu.edu/shen_j/spectral/projects/, you can download the proj2.pdf. From the second set of boundary conditions of problem 2, you may find a trick on this method !?
-Paul
Old   March 6, 2002, 10:41
Default Re: Poisson eq. with Chebyshev collocation
Patrick Godon
Hi Paul,
I had a look at your 'homework' and it seems that the second bc in probleme 2 is that
u(-1)=u'(-1)
or that the function is equal to its own derivative... I am not sure what physical sens this makes and it does not seem very clear, unless u(-1)=u'(-1)=0 ....
However, it is a condition on u(-1) not on u'(-1). And the main problem here would be that you have to compute the derivative of the function (u') at the boundary point and then impose this value on u at that boundary, and this would not be self-consistent.. an easy way would just be to change a0 in the expansion of u, such that u=u'.
However, the best way to do it, is as follows: Usually if you have a bc like u'=0, you change the value of u at the boundary such that u'=0. This is done by writting u'(xi) as a function of u(xj). Then you get one equation u'(xi=-1) = 0 (xi=-1, i=0), this gives you a relation between all the u(xj), j=0, 1, ..N. You then solve for u(xj=-1) as a function of the other u(xj). Here, I guess you could also solve for u'=u, u'(xi=-1)=u(xj=-1), you will have one equation where u(xj=1) appears on both sides, and you will have to solve this explicitly for u(xj=-1).
You have to bear in mind that the value that you impose in this particular case on u(x=-1) is computed from the numerical probleme, it is not a fixed value like 0, -1, -5, or whatever. Thus if there are small numerical oscillations, and you solve also as a function of time, these oscillations can amplify. Fortunately it is not the case here.
Let me know if I was clear enough,
Cheers, Patrick
Old   March 7, 2002, 02:24
Paul
Thanks Patrick. The algorithm your described is very effecient in treating Helmholtz equtions occuring in solving NSe. For that equation, I always can get correct solution (I see). What I am really concerned is the Poisson equation which with the Neumann boundary conditon may pose a ill-condition matrix. But unfortunately, I can not find a reference EXACT on this topic. If you can make time, try to solve this simple 1D Poisson equation with Direct Chebyshev collocation method
u_xx = f in x=[-1,1] and f = - pi^2 sin(pi*(x-0.5))
exact solution: u = sin(pi*(x-0.5)); at x=-1, u_x = 0; at x=1, u=1.
Chebyshev collocation method Sun Yuhui Main CFD Forum 3 May 6, 2012 02:46
DNS Incompressible : poisson order and Div(Ui) moomba Main CFD Forum 8 May 26, 2009 08:17
Recommendation of a good poisson solver Quarkz Main CFD Forum 2 December 2, 2005 09:12
Poisson Equation in CFD Maciej Matyka Main CFD Forum 9 November 10, 2004 11:30
Poisson solver Steve Main CFD Forum 6 July 22, 2004 21:16
