Debris flow modeling for landslides
Like Tree1Likes
  • 1 Post By George Bergantz
Old   March 20, 2002, 09:34
Default Debris flow modeling for landslides
Augusto
Hi all
I am looking for a commercial software able to model with sufficient accuracy a debris flow for the simulation of a landslide.
I don't have time for modeling myself so i need whatever CFD software which could approach the problem.
Thanks
Old   March 20, 2002, 10:03
Default Re: Debris flow modeling for landslides
Joel
do you know the rheological properties of the landslide and if so what are they?
Old   March 21, 2002, 01:04
Default see previous thread 3/5
George Bergantz
There is a thread below started March 5 on this topic.
Many of the commercial codes have some track record with fluidization which is the closest engineering application, but with manifestly different scales. It is a very difficult problem because the upper surface is a free surface, fluid loss and there is a range of particle sizes. So the short answer is that most available codes are not likley to yield a quick result that is useful.
But see below.
huijiaya123 likes this.
Viscoelastic flow modeling in rotorstator system vulda OpenFOAM Running, Solving & CFD 4 December 25, 2017 03:01
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
PhD in turbulence Hans Main CFD Forum 14 October 8, 2001 03:03
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 09:21
