June 12, 2009, 17:50 |
icem hexa mesh parts pb
Rep Power: 17 |
Hello dear colleagues,
I’m simulating a flow over a symmetrical NACA airfoil using ANSYSCFX11.so,to have a multiblock structured mesh, I have done a 2d extruded mesh using ICEM HEXA(v11).the steps followed are: 1-generating 2d geometry (airfoil+rectangular domain) using a scripts file. creating parts representing geometry families. 2-2d blocking (several operations) and 2d mesh. 3-extruding (1 layer) the 2d mesh after converting to unstructured mesh. Results: having a 2d extruded mesh. But parts still representing lines and not sides. making pb to introduce boundary conditions (inlet,outlet,wall and airfoil). please, I will be grateful to receive any idea or suggestions. |
June 13, 2009, 12:42 |
Icem extrusion & families
Charles
Rep Power: 18 |
There are options that you can set on the extrusion menu. You can give a new family name for the volume part, or ineherit it from the initial plane, for the "sides" you need to inherit from the line elements, and then set a new name (such as symmetry2) for the "top" part.
So when I do this, the initial 2D "volume" is called SYM1, the extruded volume is given the name FLUID, the sides inherit their names and the new outer or top face is given the family name SYM2 |
July 7, 2009, 15:30 |
that helped,but..
Rep Power: 17 |
Thanks a lot Charles,it helped well.
but there is a pb whith some lines and shells that need not to be(on profile part,and top part). |
icem hexa mesh beginner | icem beginner | FLUENT | 2 | July 9, 2008 07:27 |
ICEM hexa mesh 2d car example | icem student | Main CFD Forum | 0 | May 11, 2008 19:17 |
ICEM hexa mesh tutarial 2d car problem | cfduser | CFX | 2 | March 9, 2008 09:40 |
mesh adaptation for hexa mesh | Pete | CFX | 4 | April 6, 2005 18:43 |
ICEM Hexa - Deleting Empty Parts!! | James Date | CFX | 4 | December 23, 2004 01:24 |
