effective viscosity in RNG k-e turbulence model |
August 19, 2002, 12:29 |
I need to calculate the effective viscosity when using the RNG k-e model, and I have two questions: 1. A differential equation for the effective viscosity calculation is provided in Yakhot's paper where the origin of the RNG k-e model was discussed, but I found that the formulation of this equation is different from the one that's given in Fluent manual. I don't know why and which one is correct. 2. In the equation provided by Yakhot, the value of a constant C is not given explicitly. I found it might be 75, but not sure. Could someone please give me an answer to these? I'd appreciate it very much. Ellen |
Modified k-e turbulence model UDF | Travis | Fluent UDF and Scheme Programming | 7 | November 11, 2018 20:21 |
Power - Law Viscosity Model for Polymers | NickolasPl | OpenFOAM | 2 | August 12, 2011 08:26 |
question about turbulence model selection and sensitivity | karananand | Main CFD Forum | 1 | February 26, 2010 04:41 |
Regarding Implementation of Hershel Bulkley Model in Viscosity correlation | Pathak | FLOW-3D | 0 | August 24, 2009 06:34 |
