convert velocity in momentum source
Old   July 26, 2002, 02:32
Default convert velocity in momentum source
Mark Render
knowing the measured velocity distribution in the propeller disk and the thrust and moment I want to convert that data into forces for every cell in the propeller disk to model the propeller by source terms. So I think that the velocity distribution caused by the source terms should be the same than in the measurements.
Does some know how to do it in detail or know a good detailed reference for that.
Thanks,
Mark
Old   July 26, 2002, 17:20
Default Re: convert velocity in momentum source
Wen Long
This is an inverse problem. If the domain is simple and the flow not too complicated and linerization is allowed. You may use the Fourier transform method to find the transfer function between the Velocity and Force (source term) in frequency domain. Then construct the source = sum( T(w) *V0(w),for all w) where w is frequency and V0 is amplitude and T is the transfer function.
Otherwise, I don't have good idea,
Theories like wavemaker theory address alike problems though not exactly the same.
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
Momentum Source in an accelerating frame fakir CFX 7 December 2, 2006 04:00
no enthalpy change across the momentum source Atit Koonsrisuk CFX 2 December 19, 2005 02:33
Momentum source value Jackie CFX 4 August 3, 2003 10:07
