Heat Transfer Coefficients: Predictive Capability
Old   July 30, 2002, 13:28
Default Heat Transfer Coefficients: Predictive Capability
Chris
I am curious as to the capability of CFD in predicting convective heat transfer coefficients. I am primarily concerned with attached flows in high turbulence regions; conditions similar to those found in turbomachinery applications. Any personal experience or publication references would be greatly appreciated.
Thanks, Chris
Old   August 8, 2002, 04:03
Default Re: Heat Transfer Coefficients: Predictive Capabil
pfadix
You may contact your local CFX vendor. They recently have published a report in which they compare different turbulence models for different heat tranfer problems.
Abstract.
The report presents heat transfer predictions based on the CFX software suite for advanced CFD simulations. A series of nine testcases has been computed with the k-epsilon, k-omega and the SST model. The model formulations are given in detail including a description of the near wall treatment of the equations, which was found to be of major importance for accurate heat transfer predictions. It is demonstrated that many of the previously reported poor results for eddy viscosity models are a result of the applied low-Re near wall treatment and not so much of the underlying turbulence model. The results of the simulations with CFX are compared with other models given in the literature, including some recently published results. It is shown that the SST model, in combination with an optimal wall treatment, does provide highly accurate results for a wide variety of heat transfer testcases.
Old   August 16, 2002, 14:31
curious george
pfadix,
Would you please post the name of the paper. It is difficult to search by abstract.
George
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Heat Transfer Coefficients Ashish Kumar Gupta Siemens 6 November 22, 2001 02:50
heat transfer coefficients with "bad" yplus Andrew Main CFD Forum 4 April 8, 1999 04:43
