thermo-flid modelling+multiphase flow
Old   September 3, 2002, 00:28
Default thermo-flid modelling+multiphase flow
Ajit
Is it possible to model thermo-fluid interaction, in which the fluid involves phase change. Water and steam alltogether. water falling on a heated plate and becomming steam, and changes the temperature distribution in the plate. Please help me with your valuable suggestions....thnx
Old   September 3, 2002, 00:30
Default Re: thermo-flid modelling+multiphase flow
steve
I suppose fluent can do this......they might reply to ur problem.....
Old   September 3, 2002, 04:56
Nico
Yes, but only the new version Fluent 6.0 can do such multiphase flow with heat and evaporation. I did the same thing for cooling plat in metallurgy.
Old   September 3, 2002, 06:33
Ziad
you'll have to couple the two-phases with mass and momentum source/sink terms relative to evaporation/condensation. probably a segregated solver for resources since you're solving the entire system with energy and very likely turbulence.
Some quiestions on multiphase flow fjalil CFX 4 June 17, 2009 12:32
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 05:16
modelling blood flow in arteries with starcd sara Siemens 5 April 10, 2007 09:17
Multiphase flow modeling Paul CFX 2 August 11, 2003 09:41
multiphase flow Shane Gillis FLUENT 10 August 28, 2000 19:12
