What is "SIMPLE algorithm method"??
Old   October 5, 2002, 04:04
Default What is "SIMPLE algorithm method"??
zqnwpu
Hello,my friends:
I am a student of learning aerodynamics.Today I have some difficulties in my study. I am using a code that the author said "it incorporates the FVM useing SIMPLE algorithm method ".
But i don't know what is it. Where can I find the book or paper about it?
I appriciste for you help.Thank you!
Old   October 6, 2002, 02:32
Default Re: What is "SIMPLE algorithm method"??
Rami
Hi zqnwpu,
I recommend the book
S.V. Patankar, Numerical Methods in Heat Transfer and Fluid Flow, Hemisphere, 1980.
Patankar - together with D.B. Spalding - developed the SIMPLE algorithm in 1972. The book is also very clear and well-written.
Rami
Old   October 6, 2002, 09:37
Holidays
SIMPLE = Semi Implicit Methode for Pressure Linkage Equation
SIMPLER = Revised
But there are others such as PISO, SIMPLEC, th latter being pretty good.
Used to link the calculated velocities to the guessed pressure field in order to update the latter in the continuity eqn.
The above uncoupled methods are ALL available in standard CFD textbooks, such as Roache, or Versteeg and Malalasekera and should be documented in the code you re using.
This type of technology is now becoming superceeded by fully coupled algorithms though (in term of rapidity of convergence in general), although when different scales exis in the model it can be wise to uncouple certain equations to ease the computation (eg on chemicals MF)...
Old   October 7, 2002, 13:19
Some 1.
Versteeg and Malalasekera, as mentioned in the previous post, is an excellent introduction to the finite volume method.
Old   October 11, 2002, 04:18
zqnwpu
Hi,my friends Thank you very much,I had found some books about it!
Old   October 11, 2002, 23:21
paul
Hi! all
I am a new student for computational method. So, I don't understand what "fully coupled algorithms"and "uncoupled methods" mean. If you let me know these, I will appreciate. Bye
On the pimpleFoam solution algorithm vkrastev OpenFOAM Running, Solving & CFD 17 November 15, 2012 04:25
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai Main CFD Forum 0 April 18, 2007 03:48
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai FLUENT 0 April 13, 2007 23:17
mach-uniform algorithm for LES/DNS ilyas Main CFD Forum 0 February 22, 2007 10:53
CFD algorithm design with reconfigurable computing Beatríz Navarro Fidelity CFD 0 June 24, 2006 18:23
