Grid stretching function
Old   December 17, 2002, 02:18
Default Grid stretching function
Shahbazi
Hi I need a function for node stretching in two sides of a line. Would any body can refer me to a source (prefer accessible on the net) to find it. Any comment is appreciated. Thanks.
Old   December 18, 2002, 09:28
Default Re: Grid stretching function
chidu
can you clarify your need further? Do you want a function that makes node clustering at the two ends of a line?
regards, chidu...
Old   December 21, 2002, 02:18
Shahbazi
Thanks for your response, yes,i need a function to make node clustering in two ends of a line.
Old   December 21, 2002, 09:21
chidu
Hi Shahbazi,
There are many ways to do that. you can use any function for example a parabolic function and choose your dx based on that. I have put a file in my homepage using hyperbolic tangent stretching. This can cluster either on any one of the sides, at the center, or at both the sides (which is what you want).
You can access the F90 module at:
http://www.lkt.mavt.ethz.ch/~chidu/onedgrids.f90
Let me know if you are unable to get the file.
best, Chidu...
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
grid generator using hyperbolic tangent function Garham Main CFD Forum 3 November 11, 2006 12:04
Please help about the VTKFoam liugx212 OpenFOAM Running, Solving & CFD 0 November 18, 2005 18:27
GRID TO GRID INTERPOLATION in FLUENT calogero FLUENT 3 June 4, 2003 08:32
