May 19, 2020, 01:14 |
komegasst model
Abhishek
Rep Power: 5 |
i am tryig to model komegasst model with renumbered mesh but facing error
abhishek@abhishek-Predator-PH315-51:~/OpenFOAM/komegaSST/rrenum$ renumberMesh -overwrite -noFunctionObjects /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.0 Exec : renumberMesh -overwrite -noFunctionObjects Date : May 19 2020 Time : 10:00:19 Host : "abhishek-Predator-PH315-51" PID : 3467 Case : /home/abhishek/OpenFOAM/komegaSST/rrenum nProcs : 1 fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Mesh size: 9200 Before renumbering : band : 5041 profile : 1317462 Using default renumberMethod. Selecting renumberMethod CuthillMcKee Reading volScalarField p Reading volScalarField nut --> FOAM FATAL IO ERROR: "ill defined primitiveEntry starting at keyword 'boundaryField' on line 22 and ending at line 57" file: /home/abhishek/OpenFOAM/komegaSST/rrenum/0/nut at line 57. From function void Foam:rimitiveEntry::readEntry(const Foam::dictionary&, Foam::Istream&) in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 189. FOAM exiting |
May 19, 2020, 02:11 |
Lucky
Rep Power: 66 |
Check your nut file in the 0 dir. It's invalid. It's missing something start at boundaryField dict.
May 19, 2020, 03:00 |
this is my nut file
Abhishek
Rep Power: 5 |
| ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object nut; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 2.38581218630; boundaryField { out { type zeroGradient; } sym1 { type symmetryPlane; } sym2 { type symmetryPlane; } in { type fixedValue; value uniform 2.38581218630; } cylinder { type nutWallFunction; value uniform 0; } back { type empty; } front { type empty; } } // ************************************************** *********************** // |
May 19, 2020, 04:37 |
Lucky
Rep Power: 66 |
That looks fine actually. But you only posted 56 lines, what's on line 57? Is there maybe an extra ( ) { or } there perhaps? hmmm
Either way, somewhere starting at line 22 with the boundaryField, you're missing some punctuation in the form of a ( ) { } ; or even a space or carriage return. |
viewFactor radiation model stuck | shach934 | OpenFOAM | 1 | May 25, 2021 11:01 |
Floating Point Error with kOmegaSST Turbulence Model | shipman | OpenFOAM Running, Solving & CFD | 5 | January 4, 2016 08:57 |
manualInjection model in sprayFoam | Mentalo | OpenFOAM Running, Solving & CFD | 1 | April 2, 2014 09:29 |
komegaSST model | stix | OpenFOAM Running, Solving & CFD | 5 | March 4, 2013 08:30 |
K - epsilon VS SST turbulence model | Maicol | Main CFD Forum | 0 | November 30, 2012 16:25 |
