Parallel Plate Rheometer vs Cone & Plate
Old   March 19, 2003, 11:49
Default Parallel Plate Rheometer vs Cone & Plate
beginner
I have been reading some stuff on parallel plate rheometer & cone and plate and have come up with the following doubts. I would really appreciate if someone could guide me with this.
Are Edge effects more prominent in Parallel Plates as compared to Cone and Plate?If so why?
How does the accuracy of measurement of viscosity through parallel plate compare with the the measured value through cone and plate?
what is the operating range of angular velocity as compared with cone & plate?
to measure N2 from the difference of the measured normal stresses through Cone and Plate and Parallel Plate instruments, do we use the same Height difference?
why do we talk of cylindrical interfaces in parallel plates and spherical interfaces in cone and plate?
thanks a lot
beginner
Triangular mesh - fully developed flow between parallel plate Amir_Ghasemi Main CFD Forum 3 November 28, 2010 04:52
Flow Between Two Parallel Plate interawe FLUENT 6 March 23, 2009 04:51
Flow between two parallel plate Mustafa Ayad FLUENT 1 February 23, 2009 07:08
Flow in a parallel plate Andre FLUENT 0 November 24, 2008 14:37
free convection between 2 infinite parallel plate runny craven Main CFD Forum 2 September 19, 2001 05:45
