CFD vs Experimetal Results for Aerofoil
Old   April 22, 2009, 07:14
Default CFD vs Experimetal Results for Aerofoil
Anth
aceofharts414 is on a distinguished road
Hi, I'm comparing experimental results obtained for a NACA 0012 aerofoil in a wind tunnel with CFD results ran on Fluent.
The CFD model was a very simple 2D, steady time, incompressible model using k-epsilon and standard wall functions. BC's were a pressure inlet and outlet and symmetry on upper/lower surfaces or fluid domain.
Despite the low inlet gauge pressure of 215pa, I'm getting pressure readings on the surface of the aerofoil that lead to pressure coefficients greater than +ve 1 on the pressure surface at 9 deg and 12 deg incidence.
Can anyone explain why this may be happening? Is it a problem with the wall function?
Thanks
Anth
aceofharts414 is offline   Reply With Quote
Future CFD Research Jas Main CFD Forum 10 March 30, 2013 12:26
DOES ASPECT RATIO PLAY A PART IN CFD RESULTS? RIF Main CFD Forum 2 January 5, 2008 13:14
ASME CFD Symposium Chris Kleijn Main CFD Forum 0 August 22, 2001 06:41
CFD JOBS and Expected Salary.... Noel Harrison Main CFD Forum 11 November 22, 2000 07:15
Can we quantify the fruits of CFD? Brady Brown Main CFD Forum 14 December 15, 1999 09:42
