August 14, 2003, 17:43 |
Specified mass-flow rate in an outlet
Hy there!
I'm currently trying to implement a boundary condition into a 3D Finite Volume method. This bc should handle an outlet in which the user know the mass-flow rate. The bc actually modifies the exit static pressure in each iteration in order to reach the prescribed mass-flow rate. I have a doubt, however: What's the equation that relates mass-flow rate and the pressure? Does any one now it? I know some commercial codes do it, but I couldn't have access to the proper formulation. Does anyone have any idea? Thanx a lot in advance. Biga |
August 15, 2003, 04:40 |
Re: Specified mass-flow rate in an outlet
The equation you are looking for is the Navier-Stokes equation, relating velocity to pressure and therfore massflow to pressure.
August 15, 2003, 22:02 |
In general the pressure gradient is given by irrotational part of (-u.grad(u) + 1/Re*del^2(u)) + conservative forces, which cannot be expressed in terms of flow.
For the special case of fully-developed internal flow, a relation of the form you described does exist. It is of the form: grad(p)=c_p/Re*phi, where phi is the net internal flow, Re the Reynolds number, and c_p is known as the "Poiseuille constant". c_p depends only on the flow geometry, and is 3 for flow in a 2D duct. |
August 17, 2003, 21:02 |
Thanks, Jonas
That's more "implementable"... =D However, that gradient would make it a bit harder... :\ I've been looking in the Fluent UDFs and found one equation, which is delta p = MFR_desired * delta MFR / (rho * area^2), where MFR = mass flow rate. Do you where this equation comes from??? I've tried the implementaion with a pressure "driver" of my own, written as: delta p = p * delta MFR / MFR_desired, and it seems to work, what makes me think that I don't really need a physical equation but only a driver to the desired pressure. Weel, thanks again anyway, Biga |
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 02:10 |
CFX turbo - Mass flow rate | Vashishth Patel | CFX | 7 | April 3, 2014 20:33 |
How Other Conditions Impact Mass Flow Rate Outlet | andy P. | Main CFD Forum | 2 | February 9, 2007 10:41 |
Mass flow rate at outlet | Leon | FLUENT | 7 | October 22, 2004 07:36 |
Mass flow rate | Neser | CFX | 4 | February 14, 2004 00:27 |
