Icepak Reverse flow.
Old   October 16, 2007, 01:53
Default Icepak Reverse flow.
Ashish
Hi I am simulating forced convection in a cabinet mounted with fans on one side and opeing on the other side. With no resistance to flow inside, I could achieve good flow convergence but if I insert PCBs inside the cabinet, I am getting reverse flow at the inlet. What should be the problem ? Is there any way to avoid it ?
Old   November 6, 2007, 05:33
Default Re: Icepak Reverse flow.
jerry
Hi Ashish,
I am getting the same results on my models when I do forced convection. Unfortunately I do not have a solution for you. However if you do find a solution I would appreciate it if you were willing to pass it along to me. If I discover a soultion in the interim I will let you know. I am searching the web for answers.
Thank you,
Jerry
Old   December 12, 2011, 05:11
Pramodh.J
Jupudi.pramodh is on a distinguished road
Send a message via Skype™ to Jupudi.pramodh
Hi Ashish,
Reverse flow is a common phenomenon we can observe in forced convection, when there is an obstruction to the flow.
The reason behind this is , when there is any obstruction to the flow, the flow tends to deviate from the path. During such cases, depending on the pressures, there is a chance that the reverse flow might happen. This is commonly observed in high velocity cases of forced convection.
Best regards,
Pramodh
Jupudi.pramodh is offline   Reply With Quote
Reverse Flow Bharati FLUENT 0 September 14, 2010 01:09
Flow simulation in reverse drum mixer Patel Chirag CFX 0 July 19, 2010 15:05
reverse flow alikami FLUENT 1 June 2, 2010 04:19
reverse flow kiao FLUENT 4 May 26, 2005 14:08
reverse flow Giovanni FLUENT 11 October 15, 2001 03:01
