Kinetic Theory in Multiphase
Old   June 3, 2009, 22:54
Default Kinetic Theory in Multiphase
mtl
Mooktzeng
mtl is on a distinguished road
Hi, I am doing research into CFD modeling of fluidized beds & cyclones. For the past one month I have been trying to use multiphase models, to no avail.
I decided to post this thread to clear some doubts on the use of kinetic theory in gas-solid simulations, and hope that it helps other researchers as well.
Please comment if any users have found the following observations contradicting
The dynamic viscosity required for a 'solid' material does not matter. No matter whether the value is from 0.05 till 1e-7 [Pa.s].
The kinetic theory will work with the granular temperature model of zero equation. The alternate algebraic equilibrium model always cause an overflow in the solver (this is the default model in CFX).
Literature suggest using Ding & Gidaspow's model of equating the granular temperature with velocity fluctuations, which is represented in another form in the zero equation anyway.
Without the kinetic theory, the simulation can still run. However, the drag coefficient would be different. Velocity profiles would remain the same as well.
mtl is offline   Reply With Quote
fluidized beds, granular temperature, kinetic theory, multiphase
udf for cohesive forces in kinetic theory T.Hari FLUENT 1 October 6, 2014 14:41
Mixture model and kinetic theory Fuping Qian FLUENT 3 January 24, 2011 06:58
CP - KINETIC THEORY Leo FLUENT 0 October 15, 2007 10:40
Kinetic Theory Tommaso Main CFD Forum 1 June 30, 2003 10:06
solid kinetic theory wan xiaotao Main CFD Forum 6 August 10, 1999 18:43
