July 24, 2009, 02:06 |
moving airfoils very immediate
hasan amini
Rep Power: 16 |
hi
I have a problem and I will be very thankfull if any1 help me. consider a problem in that we have 2 airfoils near each other and we want to view the influence of movint one of them on the other. I mean one of them will change its angle for example. 1-can this problem be solved by a cfd approch? 2-Is this a transient problem? 3-what can i do with the mesh? (is a movable mesh a good idea? how?) regards. |
July 24, 2009, 09:08 |
Considered a panel method?
Richard Smith
Rep Power: 17 |
If you are mainly interested in lift force and pressure drag (no viscous drag) away from the stall condition then you might consider a panel method. Panel methods only require a surface mesh so the movement part is relatively easy compared to general field methods that require a volume mesh.
[Marketing] Here at Symscape we have a transient 3D panel method with rigid body motion that may suite your needs.
Symscape, Computational Fluid Dynamics for all |
HELP - Moving car simulation in fluent | Brad Wells | FLUENT | 7 | January 4, 2018 19:55 |
How to make boundary layer mesh moving with wall | wayne | FLUENT | 3 | June 11, 2008 23:23 |
C4 = 1 for Moving Mesh | Xobile | Siemens | 2 | January 18, 2005 05:22 |
Moving Mesh Problem in Unix Platform | Arnab | Siemens | 3 | August 16, 2004 08:59 |
moving cylinder | blur boy | Main CFD Forum | 4 | October 12, 2001 05:32 |
