Parallel solvers
Old   October 15, 2003, 05:46
Default Parallel solvers
srik
Hi all, Can any one suggest me the parallel algorithms for solving 3D NS equations(incompressible flow, viscid). Please suggest me any papers regarding algorithms.
thanks in advance,
srik
Old   October 15, 2003, 16:45
Default Re: Parallel solvers
araz
One of the best way of parallel processing is data partitioning,make your stiffness matrix in a way that use parallel solvers, the best parallel solver is PETSc library, you can download the PETSc library from : www.mcs.anl.gov
araz
Old   October 17, 2003, 00:59
srik
Hi Thank you for your response but I don't want to use any parallel solver, I would like to implement parallelisation with in my own code. For that I need to know different algorithms present in the literature which are efficient. It will be grateful if any one can suggest some algorithms which I can try to implement.
thank you, srikanth
Old   October 17, 2003, 02:46
araz
In the hardware view point there are two kind of parallel machines multi processors and multi computers programming in multi processors is somehow similar to sequential one but multi computers are complex.If you've programmed your code sequentially without prallel consideration,changing it to parallel can be difficult, but if you want to use multi computers can refer to following text boot Parallel Programing with MPI by Peter S. Pacheco
Ignition fails in parallel run combustion solvers msha OpenFOAM Bugs 17 January 17, 2009 03:49
Understanding parallel solvers milkovp OpenFOAM Running, Solving & CFD 3 May 20, 2008 17:07
Parallel direct solvers khurram Main CFD Forum 0 January 17, 2007 16:45
Parallel run with different solvers carlo_fabrizi OpenFOAM Running, Solving & CFD 19 June 13, 2006 04:57
Exporting problem from parallel solvers Kong FLUENT 6 May 4, 2005 11:55
