Euler flow in 2D nozzle/passage
Old   October 21, 2003, 23:21
Default Euler flow in 2D nozzle/passage
Ramki
Hi - I am trying to simulate the classic compressible flow through a 2D nozzle/passage using conservative Euler equations. I am trying to model this using Jameson's finite volume formulation with artificial 2nd & 4th order dissipation.
I was clearly having a lot of trouble implementing the boundary conditions - especially the inflow & outflow conditions. Jameson did not seem to have spent a whole lot of time discussing BCs, except how to impose pressure BC near a solid wall.
I was referred to the excellent work by KW Thompson about non-reflecting boundary conditions based on the characteristics. With this I was able to simulate the quasi-1D flow through converging-diverging nozzles for all sorts of boundary conditions. I now want to model the flow in a 2D passage.
I guess if I used structured grids, I could map the flow domain to a rectangular computational domain, and use the non-reflecting BCs for analysis. How about if I tried to use an unstructured grid ? My question is this: is there some web-reference(s) or journal reference(s) that refer to this problem. This is a basi problem, right ? I could not find straightforward references on the web that directly addresses this flow problem in 2D.
Would greatly appreciate pointers. If this subject has been discussed before - I apologize, please point me to the right direction.
Thanks. - Ramki
Question about Euler solver for incompressible flow qtian OpenFOAM Running, Solving & CFD 3 March 27, 2018 05:34
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
Fully Developed Flow in Star-cd SMM STAR-CD 0 September 5, 2011 22:08
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
