1D wave equation
Old   October 27, 2003, 13:44
Default 1D wave equation
rvndr
Hi
I am trying to solve 1D wave equation using eulers explicit scheme.After Discretization I am getting the following equation.
[Ui^(n+1)]=[v^2*U(i-1)^n]+[2(1-v^2)*Ui^n]+[v^2*U(i+1)^n]-[Ui^(n-1)].
The problem that I am facing is with the last term -Ui^(n-1).Because the values at (n-1) level are not known.We know only boundary conditions at nth level and are trying to find out at n+1 level.Then how to solve this equation.
Where v=c*(delta t/delta x);
Any help in this regard is higly solicilated.Thanks in advance.
regards rvndr
Old   October 28, 2003, 02:43
Default Re: 1D wave equation
Roman
at first time stpe say n=1 i.e n+1=2,n=1,n-1=0. You should use value of variable at n at n-1 are equal.One you solve everything at that time step the next time n=2 i.e n+1=3,n=2,n-1=1. Now you value of variable in n-1=1 and n=2 so you can proceed. Roman
Old   October 30, 2003, 08:30
rvndr
thanks..............i did the same way
Old   November 3, 2003, 19:01
Peter
"You should use value of variable at n at n-1 are equal."
If you do that then you've effectively implemented u(x,0)=f(x) and u_t(x,0)=0 where the u_t equation is discretized with a one-sided approximation to the time derivative. Are these the initial conditions the original poster wanted ?
Old   November 5, 2003, 04:13
Tom
The easiest way to initialise the problem
u_tt = c^2.u_xx with u=f(x), u_t = g(x) at t=0
is to use Taylor series
u = u(x,0) + dt.u_t(x,0) + (1/2)dt^2.u_tt + O(dt^3)
~ f(x) + dt.g(x) + (1/2)dt^3.c^2.f''(x) + O(dt^3)
you can use this formula to obtain u at time level n=1,
Tom.
Old   December 5, 2003, 20:28
vasanth
Use forward difference if U_t is not specified at the boundary
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Wave equation, wave velocity components mztcu CFX 1 May 4, 2010 02:14
what is the condition to use the wave equation? mmff Main CFD Forum 0 January 26, 2010 04:25
Assistance with one-way wave equation Frank Main CFD Forum 5 March 14, 2007 10:56
Wave equation with COMSOL Jeff COMSOL 0 December 6, 2006 02:27
